Where to install an oil temperature sensor...
Old 08-11-2010, 02:33 AM
Silver2KZ's Avatar
Default Where to install an oil temperature sensor...
for a 2000 Z28 automatic?
Just like the title says. Where do you put the sender for an electric sensor? I do a lot of autocrossing/track and would like to be able to monitor my oil temps.
Going to be doing a transmission temp gauge too. It seems that the sending unit from autometer will fit right in the pressure port which is great. Unless one of you has a better location?
Thanks!
-Scott
Old 08-11-2010, 05:53 AM
MTBSully's Avatar
i think you are supposed to tap the oil pan bolt but im not positive
Old 08-11-2010, 09:37 AM
MTBSully's Avatar
scratch that. after doing some reasearch it would appear that most people drill and tap the piece above the oil filter for the 1/8" NPT fitting.
Old 08-11-2010, 10:47 PM
Silver2KZ's Avatar
Are you talking about that little piece that sticks out horizontally and is held on by two bolts?
Thanks!
-Scott
Old 08-11-2010, 11:13 PM
gearhead1186's Avatar
Thanks!
-Scott
yes sir
Old 08-12-2010, 09:25 PM
Justus67's Avatar
glow shift gauge pods have a sensor and adapter that go between the oil filter and pick up. No drilling and tapping.
Old 08-13-2010, 02:39 AM
SS4Luck's Avatar
im using this thing for my psi and temp gauge
Old 08-13-2010, 10:08 PM
Flawless02SS's Avatar
I drilled and tapped the piece by the filter. Very easy, no problems going on 4 years now.
Quick Reply: Where to install an oil temperature sensor...
