LS1 vs LS6 Intake
Old 08-11-2010, 01:57 PM
duaneduanet's Avatar
Default LS1 vs LS6 Intake
I have a 2002 trans am. and I am putting a 1999 corvette engine in it due to the engine blew on me with only 83,000 miles.
I have heard that the 01-02 trans am's had a ls6 intake. Is this true? and how can I tell? Does anyone have the part # for the lS1 and the LS6 intake? because if my trans am intake is a ls6 I will swap it onto the ls1 vette engine. Going to look at the vette ls1 engine today.
Old 08-11-2010, 02:00 PM
86zcamaro's Avatar
If its original it is the ls6. 01 and 02 ls cars got the ls6 intake and its supposed to be good for 10-15 over the ls1.
The front will be flat and it wont have egr, other than that read about it or wait for other posts because thats all ive remembered from what ive read honestly.
Old 08-11-2010, 02:10 PM
The 99 vette rates at 345 so that means when I change engines\and intake I could get 355-360hp? Is it a easy swap? I plan to put headers on it also. Is there anything else I should take off my trans am engine and put on the vette engine?
Old 08-11-2010, 02:17 PM
2001NBMZ28's Avatar
If it's original it's a LS6 as stated above. There are a few part numbers, mine came with PN 12561184 from the factory. Post up the PN or look in the parts number sticky. ls1howto.com has an intake swap guide for both the vette and f-body.
Old 08-11-2010, 02:23 PM
the part # on my intake is 12573572
86zcamaro's Avatar
I think they either rated the same engine higher for the vette or maybe it has a more aggressive cam/ tune from the factory.
But the ls6 on there isnt going to hurt it and should add a little. Those numbers are also at the engine, I would expect about 330ish at the wheels maybe with the ls6 on that engine.
Old 08-11-2010, 02:24 PM
anything else i should use off my 02 trans am?
Old 08-11-2010, 02:37 PM
2001NBMZ28's Avatar
That's a Z06 LS6 intake.
Old 08-11-2010, 02:44 PM
Theblacknightls1's Avatar
ls6 intake and you have a bit better flowing heads than the vette. I think it has the 853 heads and you have the 241 heads. If you do swap heads its better just to go with stock 243 that are pretty cheap now. But that would be the only thing I would swap out as far a performance. Are you keeping the Tb from the vette (electric)
Old 08-12-2010, 11:36 PM
I bought the engine yesterday and hope to have it installed by Monday. So I should put the heads currently on my 02 trans am LS1 onto the 99 Vette engine? Is the throttle body the same? If not which is better? Also where is the # on the block to tell me the exact car it came out of and year? I found the # on the block that is below the driver side head that code is 12550592 and from another post that means that it is a 97-up engine but that doesn't help I knew that because the ls1 came out in 97 lol. I have heard the term "derivative vin" but don't know where that is and if that will tell me what I want to know. Also the Part # on the new engine's intake is 12560688 if that helps any.
Old 08-12-2010, 11:59 PM
Intake part #s ls1:12556333 ls6:12561182 z06 ls6:12573572 check casting numbers on the heads 99 vette should have 853 heads and your 02 t/a has 241 heads.
Old 08-13-2010, 12:00 AM
It will say853 0r 241 on the heads
Old 08-13-2010, 12:01 AM
Your t/a has a cable tb the vette should have a eletric tb. Just use your tb off your t/a
Old 08-13-2010, 12:08 AM
does anyone have the specs of both the heads? should i keep the cam that is in the vette engine?
Old 08-13-2010, 12:49 AM
Jeff Smith's Avatar
Default is that Ls1? Correct?
Just curious, I look at the intake part# 12560688 I took it out from 2000 Camaro.
Attached Thumbnails LS1 vs LS6 Intake-dsc02757.jpg   LS1 vs LS6 Intake-dsc02766.jpg
Old 08-13-2010, 01:25 AM
99SSJarhead's Avatar
Keep the heads and cam that are already on the vet engine and swap over your ls6 intake and throttle body.
The f-body cam just isn't special enough to swap over and an mild aftermarket cam would only cost a small bit more and would be a better investment.
Old 08-13-2010, 12:18 PM
adkunlimited's Avatar
853 heads and 241 heads are basically the same. both have 66.67cc chambers, 10.1:1CR, 200cc intake port, 70cc exhaust ports, 2.00 intake valves and 1.55 exhaust valves.
Like blacknight said, its not worth it to swap heads unless your going to do 243's or better.
Old 08-13-2010, 03:28 PM
Z Fury's Avatar
That is an LS1 intake manifold with EGR.
Quick Reply: LS1 vs LS6 Intake
