Hooker Exhaust Rattle On Camaro SS
i just put my Borla on my SS and had some rattles, so i just slid under it and tapped on it and got each rattle taken care of, had to un bolt the first clamp on the I pipe too and turn the system to keep from rattling on a heat sheild,
All good ideas, but none that will fix the infamous "Hooker Rattle". I cut my Hooker open to see what it was and I found it; there is a small cylinder in the walls of the chamber inside that only has 2 small tack-welds on it. Some go for years without any problems and some rattle after first start-up. It's the only flaw I've ever heard from the Hooker and it's been an inherit problem since Hooker started selling them. Maybe you're lucky and it is just a loose connection but it sounds like it's coming from the muffler itself then you can't fix it.
