Slightly Confused (02 sensors)
Old 08-14-2010, 08:52 AM
Adam2001WS6's Avatar
Default Slightly Confused (02 sensors)
I've got all my exhaust ordered and I'm going to be replacing the front 02 sensors and having the rear 02's deleted. My question is about the Denso 02 sensors I would like to get. First off, can I just order the front Denso 02 sensors (2 of them) for the front? In other words, I know with the Bosch 13111 you should order the REAR 02s for a corvette so that they will be long enough for the FRONT locations. Is this the same for the Densos or are they already long enough? Secondly, I've looked at several vendors in MD and NC (I'm in VA) and I haven't been able to locate one that sells Denso O2 sensors. Without spending an hour seraching through all 50 states, could someone tell me if they know of one that carries them?
Thanks!
Adam
Old 08-14-2010, 01:36 PM
Flawless02SS's Avatar
just buy O2 extenions. They are around $25.
Old 08-14-2010, 03:47 PM
99SSJarhead's Avatar
The reason people use the bosch rears is because of the longer cords. If you buy the denso's you still need extensions. So it'd be cheaper to buy just extensions for what you have and easier to just buy the bosch
Old 08-14-2010, 04:06 PM
Ok, I'm trying to eliminate "extra" wiring (aka. extensions) so I'm just going to get the bosch's. Any vendors on here selling them?
Thanks guys!
Old 08-14-2010, 05:03 PM
http://www.summitracing.com/parts/BCH-13111/
