TSP true dual installation question
I started installing my TSP true duals and I forgot that it's not meant for use in conjunction with the stock torque arm. Will any aftermarket torque arm fit or could I even use the relocation bracket because its cheaper and im a little, actually a lot low on cash right now. Thanks guys
Hey
i just got done installing mine and you really have to get the drivers pipe to seat forward as much as possible I bet your running into the same thing I was where the pipe hits the arm..
Make sure that drivers side pipe is all the way forward and you should be good!
I had to beat mine on a bit wiht a small 1x6 flat board and a small sledge
it takes a little tweaking but ounce its on there its fits well! i have done this setup with a stock and after market umi torque arm and both had just enough clearance!
just keep at it! it will fit!
dont try and assemble it on the ground and lift it up as one piece! I had better luck putting the pieces on separately
work with it... it will fit!
Definately works with the stock torque arm. You do have to remove the tunnel brace, and if you want them to tuck up the best, flip the fuel line brackets upside down and push the fuel lines up away from the pipe into the flipped brackets.
you just have to work with it. make sure the pipes on the headers are on all the way. but it will fit with factory ta no problem. If you take your time you will have no problem with clearance either at stock ride height.
I just installed the TSP true duals with the Midwest Chassis tunnel mount torque arm. They have one specifically designed for the duals. Fits great and I can tuck them as high as I want w/ no problems. (bullets damn near hit before the torque arm clearance becomes a problem)
are the tsp true duals a bolt up system??? like if i ordered them off the internet, when they got to my house i could put them on myself without welding or cutting (i understand a little persuasion) and drive off?? what about hangers and such. is all of that included???
