Would this require a re-tune?
Old 08-20-2010, 12:16 AM
JeaneGrae's Avatar
Default Would this require a re-tune?
I had my car tuned for long tubes not to long ago. I have since picked up a set of 243 heads and an ls6 intake. Would a re-tune be necessary or could i hold off for a while?
Old 08-20-2010, 01:58 AM
Squirts11's Avatar
You'll be running a bit leaner now from the heads/intake's added airflow. I say cam that biotch, then get a re-tune.
Old 08-20-2010, 06:29 AM
MonmouthCtyLS7's Avatar
Like posted above if you plan on caming it do it after that..if not then get the retune.
Old 08-20-2010, 11:55 AM
fatmat80's Avatar
im with both the previos posters..however my tuner will retune my car for half price after the initial tune. if your tuner does that then i suggest getting car tuned...goodluck..
Old 08-21-2010, 01:05 AM
thegodfather899's Avatar
^^my tuner does the same. he offers re-tunes for way less than the initial. if its not ridiculously expensive for the re-tune id say go for it.
Old 08-21-2010, 02:14 AM
SMALLBLOCKHERO's Avatar
anytime you change the efficiency of your engine you should get a retune. and those heads an intake will make a big change in your power output. i say tune it, if your not planning any other mods for a while.
Old 08-21-2010, 06:43 AM
SweetS10V8's Avatar
Make sure your tuner does VE & MAF tuning.
Old 08-21-2010, 07:01 PM
ULTIMATEORANGESS's Avatar
id get a cam and retune and be done.
