How does this look?
Old 08-29-2010, 05:18 PM
Tyler_PinkertonZ28's Avatar
Default How does this look?
I wasn't really sure where to post this, so i apologize if it is in the wrong section. I've been reading a lot on here about oil pressure and where it should be, so while I was driving to the gas station I took a pic of all of my gauges at full operating temperature. Since I am pretty new to Ls1's I was just wondering if yall thought everything looked pretty normal for a 12 year old car with 141xxx miles.
Old 08-29-2010, 05:27 PM
Esco99's Avatar
I think you need gas
Old 08-29-2010, 05:28 PM
turbo's Avatar
more like a vacuum....
Old 08-29-2010, 05:30 PM
yea, having the windows down all the time due to not having A/C sucks on the interior of the car, but no school or work til tomorrow afternoon, so i think it will be getting a wash, wax, and detail.
Old 08-29-2010, 05:53 PM
sbmracer's Avatar
Pressure looks low. Mine usually runs around 200 on the pressure gauge
Old 08-29-2010, 06:08 PM
ULTIMATEORANGESS's Avatar
im guessing his car isnt warmed up yet in that pic?
Old 08-29-2010, 06:21 PM
1998flamedCamaro's Avatar
Ditto, he said it was at operating temp but the gauge looks to be JUST above 160
Old 08-29-2010, 07:16 PM
That is were it is all the time. It never even reaches the first line. Stays right below it even in traffic. It has been tuned for the fans to turn on at 175 and it may have a 160 thermostat (I dont know though, if it does i didn't install it.)
Old 08-29-2010, 07:21 PM
3.8redbird's Avatar
temp sensor may be bad
what was the outside temp that day?
Old 08-29-2010, 07:25 PM
about 95. It was fine, it just started acting like that after the tune, before it would stay at the first line until I stopped moving and then it would rise all the way to halfway and cool back down once the fans came on.
Old 08-29-2010, 08:12 PM
LS1WS6dreamer's Avatar
oil pressure seems alright for a car with that many miles. Just keep the oil changed and use a good filter. Oil filter wise I run a KN HP-2006. Last oil change I used Quaker state, this time I switched to conventional valvoline. Who knows maybe next time i will use Castrol.
Old 08-29-2010, 08:19 PM
I use mobil 1 with a mobil 1 filter most times. I typically do 5w-30 in summer and 10w-30 in winter. I don't do that with most of my cars but the guy that I got this one from did it like that and I always try to keep the same oil in a vehicle throughout the life of it.
Old 08-29-2010, 09:23 PM
senicalj4579's Avatar
Oil pressure is fine. But temp says your not up to normal operating temp. Your pressure will fluctuate but I see nothing wrong there
Old 08-29-2010, 09:27 PM
With my AC on my car steadily stays on the first line. I am assuming that running the AC makes both fans kick on, since my 91 GTA and 92 camaro RS were like that. However, if its really hot outside and I don't run the AC my car will bounce between 210 and a little bit above the first line. I am assuming fans kicking on and off.
Old 08-29-2010, 09:37 PM
Big Chuk's Avatar
Looks like you need to speed up!!
Old 08-30-2010, 08:31 AM
between oil pressure and the temp gauge, that was the main reason I was asking. I don't have AC so it don't run it unless its really cool outside. The only time that mine ever came close to 210 was if i was stuck in traffic for a few minutes and then as soon as the fans cut on it dropped right back down.
Old 08-30-2010, 12:45 PM
omarrakeen's Avatar
i think its all good. my car with ac on wont go above that tempreture, only when ac is off it goes a lil bit above that, and as for the pressure it looks good u wont be needing any thing above that
Old 08-30-2010, 03:04 PM
maybe your Tstat was changed to a 160.
Old 08-30-2010, 03:10 PM
FST SS's Avatar
looks like you don't have a tstat
Old 08-30-2010, 05:06 PM
thegodfather899's Avatar
i have the same problem with my temp gauge so i changed the temp sensor and still have the same problem. have no idea what the deal is. maybe the gauge itself??
