Any idea what to do with this intake? no egr fresh air
I just bought an ls6 intake and 85mm bbk throttle body on ebay. Guys lists it in "great shape". I get it and somethings missing! The fresh air supply on the ps top of the throttle body has been ground off, filled in, and ground smooth. Any ideas? I thought about drilling a hole and shoving a tube in to "remake" the fresh air intake for the pcv. Anyone know how I get a good fit in there? I still have the stock tb, can i remove that tube, drill a perfect hole, and jb weld it in or something? If you look on the hole on the intake side you can see where the hole starts and then has been filled in from the outside. Any ideas would be appreciated, including whether or not there is a way around using that tube.
Thanks
See pics
Thanks
See pics
This is the auction:
this is a ls6 intake with a 85 mm throttle body. the intake and throttle body is in great shape. i just took it off of my camaro for a turbo setup. with this intake my car went a 10.07 with a 408 stroker. the throttle body is a bbk. there is no reserve on the auction. the highest bidder will win this item. i also have a set of comtech fuel rails, and also 30lb injectors that i am selling on another auction if interested
I contacted him saying it was modified and that we needed to figure out a resolution... No response yet.
