Start motor without trans/flexplate?
I pulled the motor to do a front end swap, and I also pulled the 6spd, to swap for a manual setup.
Can I start the motor, with NO flexplate/trans etc connected? I know some motors are externally balanced and some are internally balanced.
Just wanted to fire it up quick before I keep doing other things.
It likely wont idle. As a matter of fact I can gaurantee it won't idle. Changing anything pertaining to rotating mass will throw the idle way off. It sometimes takes ten minutes for the computer to relearn it. Be prepared to feather the throttle to keep it running.
