no spark/power to engine acc.
Old 09-09-2010, 08:38 PM
ls1curt's Avatar
Default no spark/power to engine acc.
so i got my engine all put back together and back in the car now but i am getting no spark or power to my tps sensor. the car cranks over and the fuel pump works. is the pcm not getting power? any relays or fuses i can check?
Old 09-10-2010, 10:34 AM
incbed's Avatar
I would make sure your cam and crank sensor are connected also I would diffently unplug your injectors until you figure out what is wrong and you have spark.
Also check your fuses and relays.
Old 09-10-2010, 03:03 PM
MTN_Z's Avatar
Usually the ignition relay. That's what it was on mine when it wouldn't start.
Old 09-10-2010, 04:33 PM
ls1curt's Avatar
where abouts are the cam and crank sensors? im going through all my fuses/relays also
Old 09-10-2010, 05:01 PM
ls1curt's Avatar
all relays/fuses are good.
Old 09-10-2010, 09:41 PM
ls1curt's Avatar
turned out to be a crank sensor, thanks for the help guys
