DMH Electric Cutout keeps blowing fuses HELP
Old 09-10-2010, 07:15 PM
djfury05's Avatar
Default DMH Electric Cutout keeps blowing fuses HELP
Hey all I installed a DMH 3" electric cutout about a month ago. I tapped in the accessory plug for 12v power and grounded I believe right near the shifter base somewhere. It has worked fine up until now.
All of a sudden it keeps blowing fuses like nobodies business. I had a size 25 amp fuse in the fuse panel and it blew. I then changed it out for a 30 amp fuse and the motor closes, but does not open. When I press the close button for the cutout, the motor is making noise, but when I press the open button nothing happens and I watch the battery when pressing the switch open and it is drawing a lot more power than it is to close it. It is going well below the 13 line. What is the deal here?
I have not looked at the wiring ran through the car yet. Just looking for opinions first before I go taking it apart.
Old 09-10-2010, 07:26 PM
94'BLKBRD's Avatar
I bet the power wire on your cutout is shorting out somewhere(exposed).
Check your power wire ASAP
Old 09-10-2010, 08:59 PM
SWEET98SS's Avatar
Mine was pinched in the console and blew the fuse.
Old 09-11-2010, 12:44 PM
sittinlovely's Avatar
maybe its the motor going out, causing it to pull to many amps. hopefully something simple though.
Old 09-11-2010, 01:19 PM
mischief's Avatar
Use the cigarette lighter wire to power the cutout, any other wires I saw looked smaller gauge, mine works fine.
Quick Reply: DMH Electric Cutout keeps blowing fuses HELP
