What are all these parts? Pic inside
1 looks like the trans crossmember
2 looks like the stock driveshaft guard? idk the actual name but it bolts a little behind the trans crossmember and goes under the driveshaft
3 looks like the heat shield that bolts to the engine to protect the stock mounts from excessive heat i assume.
5 and 7 are part of the air system
9 is the stock exhaust hanger mount that bolts to the side of the transmission
the rest i have no idea
hope this helped and if im wrong im sure people will post
1. Stock trans Crossmember
2. Stupid stock stamped tunnel 'brace'
3. looks like a heat shield of some sort?
4. and 8 are the clamshell pieces for the stock torque arm, like stated above.
7. I think its the T for the AIR system.
9. is the hanger for the Y pipe. It bolts on with the through bolts from 4 and 8.
1. Stock trans k-member
2. Stock driveshaft guard / whatever you call it
3. Stock manifold heat shield that attaches to motor mount
5. Part of vacuum system, something that goes on intake
6. Possibly AIR bracket that goes on intake
7. Part of AIR system
