accessory comparison between fbody and GTO
Old 09-16-2010, 09:09 PM
81cuttysupreme's Avatar
Default accessory comparison between fbody and GTO
can anyone tell me if the accessory set up is the same between the LS1 GTO's and LS1 f body's? ihave a conversion vehicle and i'm trying to figure out what bracket i can use for a procharger set up.
thanks.
Old 09-16-2010, 10:34 PM
LSX Mechanic
Damian's Avatar
Yes it is the same on on 2004 LS1 GTO's. The power steering setup is slightly different but the pump is in the same spot.
Quick Reply: accessory comparison between fbody and GTO
