meziere water pump install problems
today i put my meziere ewp on and had a few problems.. after i put it on i went to bolt the throttle body back on and the bottom left corner was hitting on the pump so i had to grind some of the throttle body to bolt it on. Once that was done after i bolted it up the part that the throttle cable sits in (not sure what u would call it) was also rubbing on the pump so bad that i couldnt open the throttle blade so i had to grind quite a bit off the bottom of it to, just wondering if anyone has encountered any of these problems when installing theres
The OPs problems are typical problems expected according to ls1howto. Gains are said to be something like 0-15 hp i just depending who you talk to . Probably best thing about the ewp is you can run it with the engine off while you're waiting your turn at the drag strip.
We'll see how it fits on an LS3 with a FAST 102 intake and TB.
Keep in mind that if you run the race version, you will not have heat.
