After honing my block....
Old 09-27-2010, 10:47 AM
robster's Avatar
Default After honing my block....
Will stock size rings still be ok? Stock ls1 btw
Old 09-27-2010, 01:06 PM
incbed's Avatar
If a flex hone (often called a ball hone) was used then you can use stock sized rings.
But if a articulated three stone hone was used then I would have the bores measured ,because the articulated three stone honing tool removes more material than a ball hone.It just depends on the grit that was used and for how long in each cylinder the articulated three stone hone was used.
Or if it was honed with a honing machine << (I can't remember the the name for it) then I would also have each cylinder measured.
Lastly if it's not to late then I would put each piston back into it's original cylinder if it was ball honed,,,but if it was honed anyother way I would take all the pistons to the shop and have them hone each cylinder for each paticular piston and make sure they number each piston for you.
Old 09-27-2010, 01:50 PM
robster's Avatar
Ok, well im doing a complete rebuild with stock size pistons
Old 09-27-2010, 03:46 PM
daschra79's Avatar
Get a set of file fit rings for the stock bore, they come larger than needed so you can have your desired ring gap.
Old 09-27-2010, 04:42 PM
LS1TECH & Trucks Sponsor
Sales4@Texas-Speed's Avatar
I agree with daschra79, some file fit rings would work best. That way you can set it up to whats needed rather then being stuck with a certain size.
