LS6 steam tube
Old 09-29-2010, 11:10 AM
sjsingle1's Avatar
Default LS6 steam tube
does the LS6 steam tube use the LS1 gaskets under the bolt/block part of the tube assembly? I went to the dealer the other day to look at the gasket and it looks like a redundant piece on the LS6 tube since it has a nice rubber seal on the bottm of the bolt/block............so ........gasket or no gasket?
Old 09-29-2010, 12:07 PM
incbed's Avatar
Mine had a small o-ring that was pressed into the cross over blocks.
Old 09-29-2010, 04:53 PM
sjsingle1's Avatar
thats why i am thinking no gasket.......the dealer call up shows a gasket under the ls6 tubes on 2001-2 models.....but i cant see how that will work with the rubber o ring on the block
Old 09-29-2010, 05:55 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Yes they do, you need the gaskets
Old 09-30-2010, 12:35 AM
sjsingle1's Avatar
me and the parts guy looked at it and wondered how it would work.....i think it would create a leak adding the gasket on there
Old 09-30-2010, 12:42 AM
99huggerorangeZ's Avatar
The ls6 design superceded to the o-ring seal,you do not need the gasket. The o-ring is all you need.I just installed 2 ls6 crossover pipes(front/rear) when i upgraded my intake to ls6, no leaks.
Old 09-30-2010, 02:22 AM
Pwebbz28's Avatar
Some of them have the oring groove machined into them. Some do not and you then need a gasket. I have one of each in my garage. You can get the gaskets at any auto parts store.
Old 09-30-2010, 06:50 PM
sjsingle1's Avatar
mine must be the newer 1.....no gasket needed
Old 09-30-2010, 07:54 PM
Z28/2002's Avatar
Well then I stand corrected
I didn't know GM changed the design
Quick Reply: LS6 steam tube
