Car runs bad after header install...
Old 09-30-2010, 12:35 AM
CarAteMyMoney's Avatar
Default Car runs bad after header install...
Just installed pacesetters, y pipe, and magnaflow cat at the back of the y pipe going to the stock cat back with a hooker muffler
I know I have some small exhaust leaks that need to be fixed with some band clamps, but the car is popping and backfiring and it feels like I have a miss at idle
i'd assume that exhaust leaks would make the car run a little funky
does this sound like something stupid like a cracked plug? because i'm pretty sure there's a small crack somewhere on of em
or is there something else going on here?
Old 09-30-2010, 02:58 AM
Nate02Z28's Avatar
I'd say you might want try getting a tune-up and a tune.
A tune-up being new plugs/cables and tune being on a dyno.
Old 09-30-2010, 05:22 AM
Engine_HP's Avatar
check ur spark plugs and wires, check spark plugs gap, make sure there is no spark plugs crack and check if the wires are connected good.
Old 09-30-2010, 07:17 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Exactly, start here. You removed and messed with all that **** and it could be mutliple possibilities.
Old 09-30-2010, 07:19 AM
Element's Avatar
Could just be a loose spark plug wire.
Old 09-30-2010, 08:18 AM
osuhog's Avatar
This is my guess.
Old 09-30-2010, 12:41 PM
i found one bad plug, it runs a little better but there's still a miss at idle... can an exhaust leak cause a miss?
Old 09-30-2010, 12:58 PM
bayer-z28's Avatar
x10 with the plugs and wires.
And exhaust leak would cause a ticking sound for a primary leak and a hissing sound for a collector leak. Shouldn't cause a miss.
Old 09-30-2010, 01:05 PM
dwightlsdub's Avatar
maybe you cracked a spark plug upon header intallation?
Old 09-30-2010, 01:06 PM
black06g85's Avatar
maybe your car is ghey?
Old 09-30-2010, 03:20 PM
MASS seller approved
smok'nZ's Avatar
i forgot th check the coils one time lol running on 4cyl it still got sideways
Old 09-30-2010, 04:08 PM
Juicy J's Avatar
Replace them all...
I had a similar problem, and inspected all of my plugs. They looked to be fine, so I reinstalled them. My car was still backfiring and popping like an Uzi. I tried all kinds of things, but finally bought new plugs which solved the problem.
There had to have been a hairline crack on one of the plugs, but I never found it. They were all gapped properly.
Its easy to damage the plugs when you do a header swap.
Old 09-30-2010, 04:11 PM
nebur8's Avatar
same **** happened to me. I was like holy hell the car sounds mean as hell!! lmao!!
Old 09-30-2010, 05:05 PM
KRAZY K 2000 TA's Avatar
plugs and wires
Old 11-25-2010, 06:57 PM
whoops - turned out to be not 1, but 2 bad plugs... with the 1 new plug it ran better but there was still a slight pop at high RPM.. now the car runs like a champ, feels ridiculous!
Old 11-27-2010, 03:52 AM
craZy28's Avatar
Do plugs and wires just incasecuz it could be one or the other, I had a wire that looked fine but was actually crap just couldn't tell.
Also check all your vaccum lines unless you did race style headers, then check to make sure all your air and egr stuffs blocked off or taken out.
Old 11-27-2010, 10:56 AM
thegodfather899's Avatar
you may wanna get it tuned as well if you havent done so
Old 11-27-2010, 11:06 AM
217zenki's Avatar
Any time there is unmetered air pulled in front of the o2's the car is gonna run shitty and rich. If I was you Id jus replace the plugs and fix the exhaust leaks.
Old 11-27-2010, 05:07 PM
i did 8 new wires and plugs and had the exhaust fully welded, no more band clamps...... she left about 150 feet of rubber without the spark breaking up and idles perfect now
Quick Reply: Car runs bad after header install...
