which goes to ground and which goes to battery on starter?
Which one of these is ground and which goes to the battery. I already know the smaller one is the keyed signal..
That's MISTER MODERATOR
There is no ground connection at the starter. The battery positive goes to the big stud that's on the left. The one on the right is the solonoid connection to the starter motor.
The ground is made by the starter being bolted to the engine.
If you connect ground to the right terminal, everything will blow up when the key is turned to "start".
