Where to get this intake? *PIC included*
Pricey, and many people speculate it's actually LESS efficient than a lid, because it has more exposure to hot air from the engine bay. It does look cool though!
http://www.ws6project.com/user_stor/...oducts_id=1206
Yea, that's just the K&N Cold Air Intake system for Ls1 F-Bodies. Volant also offer's another setup similar to the K&N system.
Here's the Volant setup for Camaro's..
http://www.rksport.com/main/part_det...mdid=1&catid=3
And here's the Volant setup for the Trans Ams...
http://www.rksport.com/main/part_det...mdid=4&catid=3
The Volant setup isn't that well made. It didn't fit well. Doesn't line up with the existing bolt-holes as it's intended to, but once I messed with it and did some drilling, it worked very well. I would definitely recommend it over the overpriced K&N. I wouldn't necessarily recommend it over the SLP lid I replaced with it, as I didn't feel any difference between the 2, but I never heard the SLP lid sucking air through the scoop.
i don't mean to go off topic, but are either of these intakes of any benefit for the larger tb/intake guys?
like if you're using a 90/90 or 102/102 setup, i'd assume you'd want a larger tube coming off the filter. what intakes are recommended for these larger tb/intake combos?
How much from summit? And part #? Looks to be stock diameter opening to the MAF?
I am using a FAST 102 and NW 102 so I plan on fabbing up my own 4" intake. I wanted to use this style of intake if I can get a 4" opening so it can go with my ram air hood and then also get ram air from underneath as well. Who knows, may end up with a 4" lid....
