ory vs catted y pipe
Old 10-03-2010, 10:27 PM
85IROCZmaro's Avatar
Default ory vs catted y pipe
i need opinions on ory vs catted y pipes and if catted y pipe wat y pipes are good and wat high flow cats there are i no slp makes some high flow cats and y pipes but whats better
Old 10-03-2010, 10:33 PM
matt224's Avatar
ORY-cheaper than catt Y's (usually buy $100 or more) and flow better. I'd only get a catted Y if you have strict emissions, or if you want to keep your exhaust less raspy.
Old 10-03-2010, 10:40 PM
ye im from NY nd i know ppl so that really isnt a problem soooo im thinkin a ory is a good choice do you know if it throws a code or not
Old 10-03-2010, 10:45 PM
matt224's Avatar
You will have a check engine light because the computer thinkgs your cats are malfunctioning. You can get it tuned out or run 02 simulators to trick the computer.
Old 10-04-2010, 10:57 AM
do u know if a diablosport tuner will turn those codes off
Old 10-15-2010, 12:13 AM
Blk_Ws6's Avatar
yes delete the rear sensors.
Quick Reply: ory vs catted y pipe
