Is it ok to Bypass Ignition-Relay-Starter Wire
Old 10-08-2010, 03:11 PM
Simplex Effect's Avatar
Default Is it ok to Bypass Ignition-Relay-Starter Wire
I've read some threads and I am having a similar issue.
My RX7 is LS1 swapped and the relay was bypassed from the Ignition to Starter Wire, it had a 30amp inline fuse that eventually started smoking and caught fire.
People have said that you can just hotwire the Starter Wire to the Ignition without issue. I tried the hotwire method and it works.
I just want to get a solid answer on if it is ok to hotwire them and be safe to drive around without a fuse or running to the clutch pedal switch.
I am guessing the only reason why the Fuse caught on fire/melted was because it was seeing too much power on the starter wire side.
Thanks in advance guys.
Old 10-08-2010, 10:47 PM
Nvm, bypassed it and the car runs fine.
Problem was trying to run to much power thru the 30amp fuse.
Quick Reply: Is it ok to Bypass Ignition-Relay-Starter Wire
