I have a FAST 102
Old 11-03-2010, 09:03 PM
ShevrolayZ28's Avatar
Default I have a FAST 102
What's the deal with fuel lines for the billet rails? The kit from FAST seems like a good deal. I can get it for $158 shipped and it includes a gauge.
I added up all the stuff separately. I figured I could put my own kit together and save money, but it works out costing more. So I figure I'll just get the FAST fuel line kit. Has anyone used this kit? Did it fit well? No leaks? Here's a pic:
Old 11-03-2010, 09:08 PM
lemons12's Avatar
One of my fittings was backwards, sponsor went out of business.. looks and fits like ***.
I didn't get a gauge either.
Old 11-03-2010, 09:20 PM
Kleeborp the Moderator™
MeentSS02's Avatar
Make sure they are teflon cores and not synthetic rubber - if they are the latter, you will have fumes from the gas breaking down the lines. I'm getting to replace every single braided line in my fuel system because I didn't know this a couple years ago when I put them in...the fumes suck.
Old 11-03-2010, 09:24 PM
lemons12's Avatar
Good info.. how do you tell the difference by just looking at them?
Old 11-03-2010, 10:18 PM
MeentSS02's Avatar
You would not be able to tell unless the hose ends were off and you could see the cross-section of the line. You can get teflon core line with a stainless braid outer that looks identical to the synthetic rubber core stuff, so just looking at that picture isn't a good indicator.
Old 11-03-2010, 10:21 PM
lemons12's Avatar
Guess I might find out in a couple years then. Lol
Old 11-03-2010, 10:31 PM
MeentSS02's Avatar
I plumbed my car with Earl's Perform-o-flex line (at least I think it was)...it was fine at first, but after a while, I really started to notice the heavy fuel smell. Put your nose next to any of the lines, and BINGO...
It is probably worse on mine because I replumbed the system to use a regulator up front, so I have braided lines in the back running from the hard lines to the tank, and the lines you can see up front in the pic below:
With that amount of lines, I'm sure that's why I smell it as much as I do. That also means it'll be that much more fun to replace them all with the right lines...I love buying **** twice.
Old 11-05-2010, 10:56 AM
Dewman's Avatar
I used that kit when i installed my 102 everything fit perfect
Old 11-06-2010, 09:19 AM
SweetS10V8's Avatar
I have also used this setup at least 4-5 times now and never had an issue. It think it looks like a really clean setup when you done. I dont know what anyone would want to change, its a "bolt on" that requires no thinking at all. Plus its cheap!
Old 11-16-2010, 05:42 PM
AW794's Avatar
This may be a silly question, but how do you connect the stock fuel line to this rail? As you know the OEM rail/line uses a snap fitting, i dont see provisions for this setup on the aftermarket rail
Old 11-16-2010, 06:21 PM
SweetS10V8's Avatar
It comes with a snap on adator for your oem fuel line that converts to -6an
Old 11-16-2010, 07:24 PM
AW794's Avatar
excellent, thanks for the info!
Old 11-16-2010, 08:34 PM
On my car that fitting required a bit of force and some cursing before it would click into locked position.
Old 11-17-2010, 07:19 AM
SweetS10V8's Avatar
You have to put the plastic part on first, then slide the fitting over it. If you try to do it all at once its a pain....
Old 11-17-2010, 08:17 AM
I did that and it was still a PITA. A little grease in the right spot might have helped too. She was a tight.
Old 11-17-2010, 05:57 PM
MeentSS02's Avatar
That's why I only use Aeromotive fittings for those...the Russel ones I tried before had this exact same problem, but the Aeromotive fittings just slip right on. Sadly, they are 2-3 times the price
Old 11-18-2010, 04:52 AM
SS4Luck's Avatar
Call Nasty Performance. I just got his fuel rail/injector/pump kit for my LS6 intake and almost bought a fast 102 for a super cheap deal this summer and called him about it and he had everything ready to go for a 102
plus you can get the rails in a lot of different colors
Quick Reply: I have a FAST 102
