used FAST 92mm intake
Old 11-08-2010, 04:21 PM
teamfbody's Avatar
Default used FAST 92mm intake
what is a reasonable price for a used fast 92mm intake? and what shall i look for(condition wise) before i buy it?
Old 11-08-2010, 05:08 PM
djfury05's Avatar
generally around $650ish.. I've seen them as low as $500 though.. condition wise I would check for any cracks, and the area where the map sensor plugs into. You'd have to take it apart to inspect the rubber seals.
Old 11-08-2010, 05:36 PM
teamfbody's Avatar
thanks this guy wants $750 but i told him i would shop around first,if i can find one for cheaper than $750 where can i take it to get it ported?
Old 11-08-2010, 05:53 PM
MASS seller approved
smok'nZ's Avatar
you can get a fast 102 around 800$ brand new
Old 11-08-2010, 06:00 PM
teamfbody's Avatar
[QUOTE=smok'nZ;14095596]you can get a fast 102 around 800$ brand new[/from where?
Old 11-08-2010, 07:20 PM
bayer-z28's Avatar
^ yeah really.. And the 102 is too big for an LS1. Unless you bolt on a 92mm TB on it. (what I was thinking of doing)
Old 11-08-2010, 11:00 PM
smok'nZ's Avatar
says who? i had a 102mm tb on my cam'd ls1 it ran harder than my 90/90 set up for sure
Old 11-09-2010, 10:16 AM
I write checks with my mouth that my ass can't cash
00blacka4's Avatar
im getting ready to do a cam in my car and i was gonna put the 102/102 on it also but everyone says its to big
Old 11-09-2010, 11:17 AM
SOMbitch's Avatar
MYTH
Old 11-09-2010, 11:20 AM
thunderstruck507's Avatar
I paid $500 for my used fast years ago, I sure as hell wouldn't pay more for it now.
Port it yourself...if you don't have a dremel they are under $50, just use sandpaper rolls and be easy with it.
Sand it lightly by hand afterwards.
Old 11-09-2010, 05:51 PM
garygnu's Avatar
TSP and ws6 store sell new fast 102mm intakes for under $850.
Old 11-09-2010, 05:57 PM
SLP4CamaroSS's Avatar
got mine for $300(plus trade my stock ported tb and ls6intake) 92mm intake and tb
Old 11-09-2010, 06:02 PM
peterlawl84's Avatar
remember if you get the 102, you will need to also factor in the cost of new fuel rails as well guys.
I picked up a vengance ported 92 for like 700 early this year. If you are patient, you should be able to find a good deal
Old 11-09-2010, 10:13 PM
lubelizard's Avatar
The Fast 90/92 is PnP with LS6 fuel rails and injectors, the Fast 102 is PnP with LS2 rails and injectors. Either intake will work but may require spacers. The Fast 102 can be had brand new for $799 from several sources. Unless Tony Mamo ported the 90/92, I don't understand people asking $700 for them. The "too big" thing is a myth.
Old 11-17-2010, 12:25 AM
smok'nZ's Avatar
yes anyone with a dremel can port an intake.........
BUT there is no way w/o experience can you port one as well as jermeyF,tony mamo,brian tooley,corry harris,etc.....
i have seen people lose power from trying to port them selfs and with a 800$ intake why risk it?
Old 11-17-2010, 09:30 AM
Not claiming I can do what the experts do. But considering my dyno numbers and track times both support a really nice gain from the ls1 before the tune for it and even with a cam that handicaps for poor intake flow I'd say I didn't hurt it any.
Just don't go crazy and do your research and most people can do a decent job for the common cam only or head/cam build. Once you look at one it's pretty obvious where some work can be done...and obviously, I understand people like Tony reshape the ENTIRE runners, not the just obvious parts and that's why he gets great results and has a price that matches that amount of quality work.
Everyone on this site is scared to death of porting. People say the same thing about porting throttle bodies...you would have to be clueless to ruin one. As long as it took to remove significant material from those with die grinders, I'd say you would have to try to mess one up with a puny dremel tool.
Old 11-17-2010, 09:48 AM
lemons12's Avatar
102 being too big for a stock cube ls1 was shown to be false months and months ago..
You will pick up less HP but more tq with a 102 than a 90 or 92.. at least from the majority of swaps I have seen, including mine. The runners were changed, I am sure that is the reason.
Old 11-17-2010, 04:40 PM
garygnu's Avatar
nitroused 383 and studderen posted pics of porting their fast intakes.
Old 11-17-2010, 06:56 PM
OMGls1jz's Avatar
so your saying the 90 or 92 will net more hp and less torque but the 102 will net less hp and more tq? i'm alittle confused by your post
Old 11-17-2010, 07:04 PM
lemons12's Avatar
From my peronal experience wih both and the majority of results I have seen, that seems to be he case.
With them changing he runners, it makes sense to me.
We are only talking a few rwhp and rwtq but it makes a difference in how the setup runs overall. i wil take tq over HP anyday.
The 102 replaced the 90 and 92 if that tells you anything.
*phone
Quick Reply: used FAST 92mm intake
