PICS OF CUSTOM TRUE DUALS with BMR TRAK PAK TQ ARM???
Old 11-11-2010, 11:25 PM
jwill_20's Avatar
Default PICS OF CUSTOM TRUE DUALS with BMR TRAK PAK TQ ARM???
Okay I just sold the catback off my car and I am planning on building a custom all stainless mandrel bend true dual setup for my 98 t/a. I am dumping it either right before or right under the rear axle. I would prefer to mount the dumps symmetrical on both sides of axle but if not possible I would still live if I have to keep both pipes on the passenger side. It is a H/C/I 402ci stroker, 4k stalled auto with full bolt ons, moser 12bolt, and it has the BMR Trak Pak TQ arm with the welded on TQ arm crossmember. I have heard of some people making their own custom TD's with this TQ arm mount and I have also heard of people modifying the crossmember by cutting it and flipping the exhaust clearanced area and modifying it to run the exhaust under instead of over the crossmember. I still have not seen a single picture of EITHER of these ways of going about it and would greatly appreciate if someone could show me some pics soon! I am using a xpipe for this system no matter what, not H pipe. I am wanting to order all the things I need within the next week. So far I cannot decide on 2.5 inch or 3.0 inch pipe (clearance vs. performance) ? Stainless or Mild steel (pricey vs. cheap)? Over TQ arm crossmember or modify to go under crossmember? And finally what mufflers if I want a nice tone with no drone or cackling and will both fit (moroso spiral flows vs. ??? Any pics and advise would be greatly appreciated. Thanks!!!
jwill_20
Old 11-12-2010, 05:28 AM
White.Lightning's Avatar
You're going to have to search. There are tons of threads on true duals and a few regarding over the axle. Spend a few hours searching.
Search advanced........
Title: true duals
Forum section: GenIII external section
Good luck!!!
Old 11-12-2010, 05:38 PM
WagnutSS's Avatar
hop on the true duals questions sticky at the top of the thread list and find a setup that looks badass and is close to what you want and shoot them a PM
Old 11-12-2010, 07:19 PM
jwill_20's Avatar
I have searched, and searched, and searched and like I stated above. Everybody says they have done it, why they did it, but No pictures, or they say they had a buddy that did it and it worked...but again no pictures and no way of contacting the person. I am not running an over the axle system. If you are going to post on this thread read the first post before you say something.
Old 11-12-2010, 07:31 PM
RJB01camaross's Avatar
I am sure you have a exhaust shop in KS that can make a X pipe and mufflers that are dumped fit.
Old 11-12-2010, 08:12 PM
SWeiser31's Avatar
Old 11-13-2010, 10:21 AM
Turo's Avatar
SWeiser, mind if I ask why you didn't do any type of crossover/x-pipe?
Old 11-13-2010, 10:30 AM
SWeiser31's Avatar
Old 11-13-2010, 11:04 AM
rooster18's Avatar
if you will go to gen III external engine and look at the top for the true duals sticky thread there are like 45+ pages of info and pics. i literally got sick of looking at pictures of setups there are so many. theres some very nice setups in there too
Old 11-13-2010, 05:33 PM
dgcustomz's Avatar
..... are you guys even reading the o.p thread? he is not just looking for a true dual setup, he is looking for those who have it setup with a BMR TRAK PAK with the welded on TQ arm crossmember
Alot of guys here have issues with these tq arm setups because the previous true dual setup was made for a stock tq arm. It is harder to route an exhaust with a tq arm mounted to the crossmember.
I have personally gone through all the pages and I can not remember any of those photos having the setup the o.p asked for. You guys need to read threads before you post.
Old 11-14-2010, 01:32 PM
rooster18's Avatar
my bad
Old 11-14-2010, 06:52 PM
jwill_20's Avatar
thank you dgcustomz for stating that! ....still no pics....anybody???
Old 11-20-2010, 08:56 PM
jwill_20's Avatar
anybody??
Old 11-23-2010, 09:31 PM
jwill_20's Avatar
Old 01-17-2012, 10:48 AM
Stryker's Avatar
bringing this back from the dead but did original op ever figure out... im in the same boat.
