drive belt setup..no a/c or P/S
Engine is a 2001 LQ4 and I am deleting the P/S and A/C. I have searched with no success and would like to know what are you guys doing for a setup on the belt drive system??
thx in advance!
thx in advance!
No PS
Just take off the PS pump and run the belt up over the idler ( by the alternator ) , then under the water pump pulley over to the tensioner.
Use a ribbed tensioner pulley so the belt rides in the grooves. ( had to shim it out, I think 4mm to line it up correctly ),
