Which intake for 90mm tb?
I've got an edelbrock 90mm tb from an old project. I'm wondering which intake I should use. I was going to go with a fast intake but recently saw the TPIS ls6 with the 90mm opening. open to all suggestions will be full bolt ons heads and cam in spring
Let me clarify- I have used two setups on my LS6 motor. One setup was the TPIS 90mm intake manifold with an LS2 90mm throttle body. I then switched to a FAST 102 intake manifold and used the same LS2 90mm throttle body.
Of the two setups, I believe the second one is better.
Well I did pick 15hp using the TPIS which is not a bad deal if you already own an LS6 manifold to serve as a "core" (Cost about $350 for the mod). If you have no manifold the TPIS cost is $850 which makes the jump to the FAST 102 intake a much better deal. The FAST 102 does have more plenum.
