headstuds which ones HELP!!!
Old 11-29-2010, 05:31 PM
Stingerrr85's Avatar
Default headstuds which ones HELP!!!
ok guys i bought a 04 lq4 block which heads studs do i buy
arp part number please!
Old 11-29-2010, 09:33 PM
That's MISTER MODERATOR
Paul Bell's Avatar
http://www.summitracing.com/search/m...?Ns=Rank%7cAsc
Old 11-29-2010, 09:37 PM
01ssreda4's Avatar
You need to double check the bolt hole depths IMO. No reason not to look for yourself. Early style should have shallow holes in the middle row on the outermost holes. 2 shallow holes and the rest deep. Later style should have all the same length holes on the bottom two rows and they should all be shallow. My 04 block used the early style
Old 11-29-2010, 09:46 PM
Paul Bell's Avatar
To be sure, call ARP.
Old 11-29-2010, 10:42 PM
NVR_SPDS's Avatar
Like was said, just measure the holes. That will tell you for sure which ones you need.
Old 11-29-2010, 10:49 PM
garygnu's Avatar
go to a good hardware store and find metric studs with the correct thread and length.
