Edelbrock Ceramic Shorty Headers and Magnaflow Heavy Metal Hi-Flow Cats
I just purchased Edelbrock Ceramic coated shorty headers and Magnaflow Heavy Metal Hi-Flow cats to put on my 2000 Trans AM LS1. Yes I know I could have gotten more out of Long Tubes, but I am going more for sound over power cause I love this car and I baby it. I already have custom true duals on this car. We cut out the stock y-pipe that was half flattened from the factory on the drivers side and ran 2.5" pipe from the cats back to an X-pipe then out to 2 SLP Loudmouth I resonators then under the axels and out. Sounds great but not quite loud enough for my taste. I strongly believe that a true muscle car should be heard BEFORE its seen . My wife hates it but o well LOL. My question is this, did I waste my money or will I notice a good difference in sound and performance with these add ons or should I just send them back. Thanks in advance for the help and try not to bash on me to hard ;P!!!!
From what I have read, not personal experience (I still have stock exhaust) you wasted your money. I remember reading that the 01-02 stock manifolds flow almost has well has shorty headers do. LT's will gove you everything you want louder/more performance about 20rwhp from what I have read. LT's are the route i'm taking when I decide to spend some more cash on the car.
Well that sucks. I don't want to go LT cause of modifications having to be done, them getting in the way of the oil plug or overheating the oil filter, having to buy O2 extenders ect... So I guess I'm screwed and I'll send the headers back if there going to do absolutely no different over stock. Anyone have any thoughts on the high flow cats or should I not do those either and just send them back too!!!
Pontiacerator
I hesitated to go to LT's like you. But I tell you, the biggest problem I had - because of the brand that I chose - was getting them in. Once they're in, no problems with drain plugs, oil filters or anything else.
I'm guessing the cats you have are the kind meant to bolt up to stock manifolds. They flow better than stock, but they're probably not worth what you paid and they won't work with LT's. I'd send them back and plan to get them with the y-pipe you get with your LT's
I won't use the Y-pipe even if I went LT's. I cut the Y out a few years ago and put true duals with an X-pipe and 2 SLP Loudmouth I resonators on it. Will NEVER go back to a Y. And I only paid $75 a piece for the cats cause I have a hook-up at my local mechanic shop. They retail for $232 but he sells me some stuff at cost!! They are universals, not made specifically to hook up to stock manifold, rather to a custom system. Motor limit on these cats is 6.2L 6000Lbs. Also stock cats flow at about 600-800 particals these flow 400!!!!
I am about to purchase the same setup but not for the same reason as you but for the fact that my 2000 SS is lowered about 1 1/2 inches. I have talked you a ton of people on a ton of different forums and the don't all say the same things. Yes Long tubes will give you the BEST but shorties will change the sound and give a few more horses the the rear tires... not a ton but some.. also high flow cats will change the sound and give a little more power so if you put the two together you will see/feel a change but not as much as if you were to put long tubes and an ory on you car.
But let me know what you ended up doing because in less then a week I am ordering the same parts....
hope this helps
hope this helps
hope this helps
hope this helps
