looking for a review on 4inch mufflex and magnaflow race muffler
Ok I saw on a website they have a mufflex 4 inch systen with a magnaflow race muffler and a single 4 inch hide away single tail pipe,any one have this system I only found one soundclip and it was awful quality,thanks guys
4" Mufflex
I have it on my 00 WS6 behind ARH 1 7/8 headers and their 3" Y pipe - no cats.
I like the sound of it. Nice low rumble just cruisin round, yet a lil loud at hard throttle.
Though It's not stock cubes either.
The quality of the Mufflex is not the best but it's ok. I had to tack weld the joints as they kept coming loose.
In rereading one of the Exhaust stickys, here's a breakdown of what HP a 3" pipe will support without any loss,
A 2.75” (stock) single system is good for a 310hp engine with zero loss…
A 3” Single system is good for a 370hp engine with zero loss…
A 3.5” Single system is good for a 503hp engine with zero loss…
A 4” Single system is good for a 657hp engine with zero loss…
A 2.25” dual system is good for a 457hp engine with zero loss…
A 2.5” dual system is good for a 513hp engine with zero loss…
A 3” dual system is good for a 812hp engine with zero loss…
Mufflex / Magnaflow sound
Here's a short clip of mine I just did. Was not quite warmed up all the way..
Camcorder was about 15 feet back.
It's a lil more mellow then the Spintech. Also the drone inside the car is more mellow.
http://www.youtube.com/watch?v=Yyt1kqF219s
Might take the camcorder for a ride later ..
Yes that's the Magnaflow 4" straight through.
I'll try n get some drive time with the cam cord. Dunno if it will B 2day.
If you want LOUD,,, I have an open chamber 80 series Chokemaster that really does not sound that bad.
Once I read that the choke master was the worst for flow, I took off the L tail pipe.
I then rigged a long tip for my torch. I cut all the baffles out, so it's just an open shell. When it was behind the stock engine, I really felt a SOTP difference above 3K rpm !
It's mellow cruising round, but WOT, it scream's..
I'll try n post a sound clip of it, but dunno when...
thread i made right after installing.(pics, my review, ppls thoughts, dyno sheet)
https://ls1tech.com/forums/generatio...installed.html
