04 ls1 need injector advice..
Hey guys.
got a 04 gto motor
i have 1 3/4 longtubes
into turndowns before axle
4 inch shorty intake
just installed
prc stg 2.5 ls6 heads
tsp tsunami heads
car has adjustable fpr from aeromotive and walbro 255 lph fuel pump/
car is still in pieces but i wanted to see if i needed to go get some 30lb ford racing injectors or do i need to go higher?
thanks guys
got a 04 gto motor
just installed
tsp tsunami heads
thanks guys
svo 30's would be fine. being that they are rated on a ford fuel system. when used on a gm fuel system i believe they actually make like 32 lb/hr or something...somebody chime in with the specs. but that's what i am running and they are no where near maxed out. but if you want the middle ground there are 36 lb injectors too.
