Drive without front o's hooked up?
So I'm putting some headers on my car.
My exhaust guy says I need to wait until I have everything hooked before he places the o2 bungs to make sure it's in the correct location.
Is there a way I can drive my car to the exhaust place with the front o2s unhooked or outside the exhaust pipe?
LS1TECH & Trucks Sponsor
It would be very difficult to drive the car without the front 02 sensors if the computer still reads off them. The computer will basically want to dump a bunch of fuel in the motor to keep it safe since there are no sensors to tell it whats going on. Usually long tube headers come with 02 bungs already welded in for the fronts.
WTF why would it be hard to drive it with no o2's? or even tow the car, seriously? dude there are harms yes. but can you drive your car with no O2s? yes you can and also 5 miles are nothing your check engine light probably wont even lit in that distance...dont worry about it
Every cold start you are essentially driving without O2's until they warm up enough to make the car go into closed loop.
It seems odd to me that your headers don't already have O2 bungs in them. And even odder still that someone needs to see them on the car before they add the bung since there is basically only a few spots on the collector where you should put them anyway.
Seriously, drama queens, calm down. The **** will be fine. There are several occasions in normal driving where the computer doesn't use the 02s to run the motor.
