PCV delete?
Old 12-16-2010, 09:38 AM
whtnuklz's Avatar
Default PCV delete?
I've searched and found a little info on this but not enough to convince me to remove it. Is there any negative effect of deleting the pcv system? I have the engine out of my car for a heads and cam swap, if i don't have to put the pcv system back in I'm not going to. My question is do I really need the pcv system on my car and will removing it have an adverse effect on the engine?
Old 12-16-2010, 11:31 AM
brian_rs/ss's Avatar
yes you do, the pcv system vents pressure out of the motor along with gases and oil mist.
http://en.wikipedia.org/wiki/PCV_valve
while you are in there i would consider going to an ls6 pcv.
http://www.ls1howto.com/index.php?article=18
Old 12-16-2010, 11:50 PM
01ssreda4's Avatar
You can't just remove the PCV system. You can modify it though.
Old 12-17-2010, 07:50 AM
whtnuklz's Avatar
That's actually what i was meaning. Just modify the PCV system and delete the stock setup. I was thinking about just putting breathers and removing some of the hoses.
Old 12-17-2010, 09:15 AM
O2Form's Avatar
IT removes ALOT of water, when I had a homemade catch can on mine it would fill a qt water every few days. I wouldn't run without it.
Old 12-17-2010, 09:29 AM
Moderator
jimmyblue's Avatar
Your oil will foul sooner and you'll see a lot more leaks.
Old 12-17-2010, 10:22 AM
whtnuklz's Avatar
well I'm fixing oil leaks while i have the engine out so I definitely don't want more. That reason alone is enough for me to just leave it alone.
