Spark plug hole fix?????
Old 12-20-2010, 01:39 PM
txh0tb0i972's Avatar
Default Spark plug hole fix?????
recently installed my heads and notice 2 plug arent treading right! so I tighted it as much as possible but its not right!whats the best way to fix the plug holes without taking off the head? they are the two center ones on driver side!
thanks!
santana
Old 12-20-2010, 02:15 PM
silversrtman's Avatar
try chasing the threads
Old 12-20-2010, 02:39 PM
is there a special tool or something!.... never done anything like this!.... just trying to get it working right that way i can get my tune!
Old 12-20-2010, 02:48 PM
TazExtreme3's Avatar
Here's a thread chaser at Sears, and one at Northern Tool
Old 12-20-2010, 02:50 PM
sweeet! will i need to put some lube on it in case some shaving decide to fall in?
Old 12-20-2010, 04:24 PM
djfury05's Avatar
Quit being lazy and pull the head to do it.. a lot safer.. unless you want a bunch of shavings sitting on top of your pistons and then scarring cylinder walls go for it
Old 12-20-2010, 05:56 PM
bayer-z28's Avatar
^ Sad but true. Less shavings, more room, the ability to CLEAN the shavings. Metal shavings in the CYLs are NEVER a good thing, but aluminum against steel? I think steel would win. But still not a good thing at all.
And if it wasn't threading right you went the completely wrong way by keep going. If it won't thread in by hand, there's something wrong. It's a 50/50 chance if the threads can be fixed. Worse comes to worse, you'll end up heli-coiling the head.
Old 12-20-2010, 06:22 PM
garygnu's Avatar
don't use too much force on a spark plug.
Old 12-20-2010, 07:27 PM
bayer-z28's Avatar
^ Right.. There's a TQ spec, but I've just always went by; hand tight till it seats all the way, then snugged down with the ratchet. A Tight-snug thing. You can do anti-seeze thing.
