turn signal problem
Old 12-29-2010, 07:53 PM
Tranzaman00's Avatar
Default turn signal problem
I have a '00 Trans Am, My turn signals work fine when I use the hazzard switch, but when I use the turn signal stick they blink all crazy in no kind of certain pattern or sometimes not at all. would that be the flasher relay unit even though it works fine when using the hazzard switch??
Old 12-31-2010, 07:50 PM
help me please guys?
Old 01-02-2011, 01:04 AM
gav91183's Avatar
Search is your friend... But, replace your flasher relay its in the right side of the kick panel by your knees... Had this happen a few months ago on my 02.. Now if your ac fan stops working, its your ignition switch.. Which was my problem..
