Oil pressure maxed out
Whether the key is turned to acc or not the oil pressure gauge is maxed out past 80 psi. I connected a lead to the connector and then to ground and I got continuity. Is this suppose to happen? Any other suggestions to narrow down the problem? Thanks for your time.
I've got the same problem. It is the oil pressure sending unit. Its located behind the intake and is a pita. I just left it until I decide to take off my intake for painting. That is most likely your problem because from what I understand, there is either oil pressure (good) or none (bad) you cannot have higher oil pressure than what your engine allows. Maybe someone else will chime in but methinks that is your problem. Do a google search for "oil pressure sending unit ls1" and you should find all the info you need.
