Ebay 92 and 102mm throttle bodies...
Old 01-03-2011, 09:12 PM
Magnet's Avatar
Default Ebay 92 and 102mm throttle bodies...
Anyone run one of these throttle bodies? This seems like a question that has probably been asked 1,000 times, but I couldn't find anything in a search..
102mm Version
92mm Version
The only thing I notice at first glance is no hole in the TB, but I could fix that problem and save $200 from what I can tell?
Old 01-03-2011, 09:21 PM
sjsingle1's Avatar
notice both of them are for 4 bolt manis........think the LS1 LS6 is a 3 bolt......no?
Old 01-03-2011, 09:29 PM
1998silverbird's Avatar
It could just be a generic picture of one of there other TB's they use. They have great feedback..
Old 01-03-2011, 09:45 PM
Magnet's Avatar
This isn't designed for an ls1 or ls6.. it is the 4 bolt pattern for a LSX manifold
Old 01-03-2011, 10:00 PM
chrs1313's Avatar
looks like a great deal to me...might have my buddy pick one up for his car...
Old 01-03-2011, 10:01 PM
InsaneAuto86's Avatar
If you order one, let me know. Excellent price! Looks like the manufacturer is GodSpeed.
Old 01-03-2011, 10:08 PM
Magnet's Avatar
If the deal goes through on my new intake this Friday I will probably be picking one of these up
Anybody know what the stock size TB hole is?
Old 01-06-2011, 03:24 PM
Magnet's Avatar
well, I ordered one of these, I'll update it with my impressions etc..
Old 01-08-2011, 05:07 PM
lq4powereds13's Avatar
Cool, i was debating on picking one up too. Let me know us know how ya like it.
Old 01-22-2011, 02:12 PM
Magnet's Avatar
Just wanted to update this thread. The TB looks great, all the machining is perfect as far I can tell. I am planning on doing some work on it though. It has similar issues to a stock TB, its just A LOT bigger!! Ill most likely do the bump stop mod, half shaft mod, knife edge blade and outer TB lip, and possibly port the lower portion of the TB. It has a slight "hump" in it on the bottom like the stock TB. Anyone know why it would have that?
The "L" rotates to wherever it needs to be and comes out. I'm not sure how tight the seal needs to be there?
You can see it has the shaft on both sides. Even if I don't do the half shaft mod, I will grind the screws flush as they protrude.
Here you can see the hump, its not huge, but it is there, and you can tell they put it there on purpose?
Old 01-22-2011, 02:18 PM
armyboyatc's Avatar
That looks pretty nice man.... Real nice.
Old 01-22-2011, 02:20 PM
armyboyatc's Avatar
Magnet, I know this is off topic but are you on SWFLracing.com?
Old 01-22-2011, 02:34 PM
LS1 BU's Avatar
Looks nice. Looks pretty much the same as the fast 102. Will a 102mm work on a ported ls3 intake? Intake opening is opened up almost to seal. Just don't know if it will seal?
Old 01-22-2011, 02:40 PM
Magnet's Avatar
Yea I haven't posted much over there, but I am. I'll probably start posting more though, A couple years ago when I joined it was a bunch of ricers so I didn't get back on till just recently..
You on sffba? I've been more active on there, but its pretty dead these days..
Old 01-22-2011, 03:46 PM
1badWS6's Avatar
What intake are you using with the TB? It says they will work with the stock manifold, is this true?
Old 01-22-2011, 03:53 PM
westtexasbuff's Avatar
LS1/LS6 stock manifolds are 3 bolt. LS2/LS3/LS7 stock manifolds I believe are 4 bolt.
This TB is probably intended for the FAST 102.
Old 01-22-2011, 04:33 PM
1badWS6's Avatar
Yup I just figured that right after I posted. Lol
Old 01-22-2011, 05:15 PM
Magnet's Avatar
Yup, fast 102
Old 01-22-2011, 07:56 PM
Could you please explain these mods?
Old 01-22-2011, 08:37 PM
Magnet's Avatar
It's hard to explain in text, but it's jut like what everyone does when they port a stock throttle body. I'll try and find a thread with pics or something.
Quick Reply: Ebay 92 and 102mm throttle bodies...
