Cam Head swap any advice
Started my cam/head/intake swap. Mild cam, 243 milled heads, and ls6 intake. Working on a A4, managed to break the OPSU and found a broken exhuast bolt driver side.
1.) I have to unbolt the dip stick to remove the passenger side exhaust? Any write ups? 2.) Any advice this is my second day working on it.
What else do I have to look forward to?
1.) Yes, there is a bolt in the side of the block, unbolt and pull up on the tube, it might be tight, but give it a tug, it will come out.
Did you get all the new gaskets needed? New Oil pump and O-ring? Do you have all the proper Torque numbers for the bolts?
Definitly go to write-up as mentioned below, lots of good info on there.
Here are some links I used below on helpful tips....
IMPORTANT....put a rag in the oil pan before you remove the oil pump screw, this will prevent it from falling back in the oil pan, you;ll see what I mean when you get to that point.
https://ls1tech.com/forums/generatio...on-needed.html
https://ls1tech.com/forums/lt1-lt4-m...-question.html
https://ls1tech.com/forums/generatio...ny-advice.html
https://ls1tech.com/forums/generatio...e-pistons.html
And finally once you are done and ready to start, go to post #10
https://ls1tech.com/forums/generatio...rocedures.html
Sounds good titan thanks. I helped two engine swaps before. Friends swapping to 6.0. This is my first 100% on my own build. Took around 8 hours to remove the complete top half minus heads. Doing exhuast and cam today. Hope monday I can start her up. Thanks darkman! I will frequent howto so I wont be surprised, I wish I had time to do this out of the bay this sucks lol.
