PS Problems
PS Problems
So last night I am just cruising and I am making an easy right turn and BAM so loud I let out a WTF in front of my 9 yo So a few blocks later I go to make a left turn and the wheel will go a little ways and stop....a 90* turn is now a 3 pt. turn Makes a shhhhh sound turning left but quiet straight or turning right... Tried to force a tight left into a parking spot and I heard a grind/pop...BTW checked resovoir and it is still full... Car will not even come CLOSE to lock turning left.
So this is pretty much the EXACT symptons when a buds truck snapped a shaft in the PS pump but it has a pump/steering box instead of the pump/rack setup we have.....
Soooooo.... anybody out there experienced this or can give me any insight into the situation????
THANKS
THANKS
Too bad there isn't an easier way to diagnose this.
I think without physically steering (engine running,) if there is no excessive or unusual noise, it may not be the pump. If you try to steer and it acts up, it may be the rack. I'll agree with the above posts on this.
Update:
Been too lazy to look at anything until today but it warmed up some so I popped the hood and took a look in the PS resovoir with the car running and NO FLUID CIRCULATING!!! So unless the rack is out too I think the pump shaft broke like I mentioned in my original post. Pulled the old pump and new one ordered. Should have it on Monday or Tuesday and will report back.......
