LQ9 to ls6 intake
LQ9 to ls6 intake
okay need help... got a complete z06 intake with rails and coolant crossover no injectors, which are still available...goin on an 6L engine in my brothers 2500 02' HD... has dual 2.5 cat exhaust with shorty headers... Putting a cam with around 600 lift. which injectors?? What do i need to install the ls6 intake on 6L engine??? and z06 springs should be good enough or upgrade to aftermarket???
any help would be appreciated!!!!!
That's MISTER MODERATOR
The throttle body location is higher on truck intakes vs. car intakes to clear the fan and fan shroud. The car intake will not work on a truck.
Truck intakes have proven to be very good performers. They just about match the performance of car intakes up to about 5,000 RPM. Even if you made it work, the power advantages will be minimal for the loads and speeds a truck engine sees.
If you must move to a better intake manifold, F.A.S.T. has a truck version.
