Alternator disassembly
Old 01-25-2011, 07:42 PM
98Camarod's Avatar
Default Alternator disassembly
How do you do it? I did a quick search on here and turned up with nothing. I want to paint the housing.
Old 01-25-2011, 07:53 PM
gMAG's Avatar
I realized that I wouldn't be able to separate the two half-shells on my own, so I went down to the local automotive electrical outlet nearby and walked in with the alternator. After explaining what I needed to do, the good guy at the counter took the alt into the back room, then came out with it separated. "How much do I owe you", I asked.
He replied, "no charge".
Don't forget to act a bit helpless while explaining your predicament.
Needless to say, I will buy my stuff at that locale.
Old 01-25-2011, 08:10 PM
sjsingle1's Avatar
it has those external torx bolts.....unscrew and separate?
Old 01-25-2011, 08:35 PM
98Camarod's Avatar
It has 4 of them I know that. I took those out. There has to be something else to it.
Old 01-25-2011, 09:24 PM
gMAG's Avatar
You might be able to separate the halves with an extra pair of hands and a few screwdrivers...one screwdriver blade at each quarter.
Place the lower half in a vise, then each screwdriver blade pry at the same time. Unless it comes out evenly, all around, it isn't coming out.
Old 01-25-2011, 10:25 PM
massls1guy's Avatar
check out this guy's videos:
http://www.youtube.com/watch?v=LdFA6WF8lVg
Old 01-25-2011, 10:39 PM
gMAG's Avatar
Mine was completely enclosed (98 LS1) and the stator was not accessable from the outside.
Old 01-25-2011, 11:20 PM
gMAG's Avatar
I'm wondering if running a propane torch around the perimeter of the half with the outer metal circumference might help you to pop it loose...just like a jar lid. That is if you have the same alt as mine.
Old 01-26-2011, 05:40 AM
silversrtman's Avatar
i used a 3 jaw puller to separate mine....but it was destructive...i didnt care cause it was broken anyway and i just wanted to see what it looked like on the inside
Old 01-26-2011, 10:13 AM
98Camarod's Avatar
It appears that the pulley must be removed in order for it to separate. Can anyone confirm or deny that? It's a 98 alternator
Quick Reply: Alternator disassembly
