This upgrade is kicking my ...
Old 02-05-2011, 01:17 AM
Texas-Firehawk's Avatar
Default This upgrade is kicking my ...
OK so I am working on a head, intake, headers, and cam swap.... but I am running into a few issues.
How do I disconnect the fuel line from the fuel rail? Can I?
How do I remove the last bolt on the passenger side rear coil pack? What tool will fit back there?
How do I get the power steering pump pulley off?
Old 02-05-2011, 01:34 AM
5w20's Avatar
Old 02-05-2011, 01:43 AM
Unertl42's Avatar
ask and you shall receive
Old 02-05-2011, 01:51 AM
5w20's Avatar
with a bonus, so he can cool off and have a laugh
Old 02-05-2011, 01:56 AM
Trunion King
bene's Avatar
Autozone sells a 3/8" fuel line disconnect tool.
Use a small rachetting close end 8 mm size wrench for the coil pack by the firewall.
Open end wrench to remove the entire pulley off the head. Don't bother removing the pulley. It's easier to remove the pump, time consuming a little but easier.
Old 02-05-2011, 07:26 AM
That's MISTER MODERATOR
Paul Bell's Avatar
Originally Posted by bene
open end wrench to remove the entire pulley off the head. Don't bother removing the pulley. It's easier to remove the pulley, time consuming a little but easier.
huh?!?
Old 02-05-2011, 07:31 AM
Wimimc's Avatar
i used a smaller socket, i wasn't able to get anything more than a quarter turn i believe. you'll prob get a lot of scratches on your arm from the cowl.
i remember reading something about that bolt, when you're done, turn around, and throw as far as you can.
Old 02-05-2011, 09:30 AM
firehawk1082's Avatar
( Dont remove the pulley, its easier to remove the pulley ) ?? I just swung my whole pump to the side while i did my heads and cam.
Old 02-05-2011, 11:31 AM
patSS/00's Avatar
Well maybe obvious, but don't remove the coil pack until after the intake's off, then reaching that bolt's a lot easier. Same goes for driver's side coil pack, if you still have the AIR bracket attached on the last bolt + bolted to back of the head.
Old 02-05-2011, 12:20 PM
5w20's Avatar
to remove the p/s pump pulley you need that special tool, if you want to remove the p/s pump assembly its easiest with a flex head ratcheting wrench. flex head racheting wrench also for the coil bracket.
to avoid scratched on your hands/arms remove the clips from the cowl.
Old 02-05-2011, 01:28 PM
Trunion King
bene's Avatar
Originally Posted by Paul Bell
huh?!?
That was a brain fart... i meant to say... It's easier to remove the pump, it's time consuming but it is easier.
Old 02-05-2011, 01:30 PM
Trunion King
bene's Avatar
I meant to say easier to remove the pump off the head than pull the pulley out. Lack of sleep owns me.
Old 02-05-2011, 03:25 PM
5w20's Avatar
i understood you, i took account the time that it was posted.
Old 02-05-2011, 10:18 PM
offroadfury6's Avatar
that last bolt is a BIA! I did it with a socket...just gotta get in there and fight the fight...
Old 02-05-2011, 10:31 PM
ahahaha just busting chops!!!!!! just be careful of the sensor when you install the new intake, i busted mine! doesnt take much!
Old 02-06-2011, 12:22 AM
cowboysfan's Avatar
pass. coil bolt- use 1/4 drive ratchet w/ 10mm deep socket and throw it away. wrench will work to remove p/s pump...alot easeir then removing pully... fuel disconnect can be rented from local auto parts store.... G/L
Old 02-06-2011, 10:20 PM
OK so got the plastic fuel line removal tool 3.99 at auto parts house. Then just undid the pump completely sooo easy. For the final coil pack bolt... get this....... If you own an LS1/LS6 like me then your bound to have a few metric 10's lying around. I took the longest one I had (of the three) heated the box end up and proceeded to bend the thing to almost 90 degrees on my gas stove. That bolt didn't have a chance. Took longer to bend the wrench than to remove the bolt. F-in smart right...
Old 02-06-2011, 11:08 PM
Paul Bell's Avatar
I have a whole drawer full of "custom" wrenches, some like 25 years old. Most I don't even remember what they're for.
This is why they make cheap open ended wrenches-for bending up.
Old 02-06-2011, 11:53 PM
cowboysfan's Avatar
any nice cuts or deep scratches!!! use some wire cutters to cut off the tips of the retainers underneath the dash, u know what i'm talking about..
Old 02-08-2011, 07:33 AM
Hell yeah, first day I was all cut up.... then I said screw this and grabbed a set of dikes and started snipping. This is the kind of stuff LS1 how to doesn't inform you about. I am starting to hate that wab site.. I have come across so much bs that was not in there its redick... I forwarded him some photos and instructed him that he is missing a few steps in his process of the head change but then again I have a 2000 TA and I think the site is for a 2001 year swap.
