can an exhaust change the way ur car lopes?
Old 02-11-2011, 03:05 PM
rob00ss's Avatar
Default can an exhaust change the way ur car lopes?
i had a slp loudmouth on my car with thunder racing 236.6/330.5 603/578/ 111.6 cam with stock heads and the car loped pretty good at idle. After i intalled the prc heads and ind intake manifold and stuff plus a flowmaster exhaust which was a mistake, you can hardly hear it lope at all. i was just wondering if anyone knows what could have changed it so much thanks
Old 02-11-2011, 03:20 PM
99Bluz28's Avatar
Is it a FM cat-back system or Mufflex cat-back system?
Old 02-11-2011, 03:38 PM
rob00ss's Avatar
its a flowmaster cat back currently on the car and i have tsp true duals on the way
Old 02-11-2011, 04:59 PM
The Mighty Texan's Avatar
Those duels will clean up that sound for sure, still think you would be able to have a strong idle through what you have already though...
Old 02-11-2011, 05:13 PM
SMOKNSS's Avatar
Muffler choice can DEFINATELY change the way a cam sounds at idle. I have a GMMG and its always hit hard. My little brother just switched from a Hooker catback to the TSP tru duals with bullets and his car sounds like a completely different car. Same cam and everything. It makes the cam sound twice as big as it did before. Most of the difference being the exhaust is dumped under the car. Every car I have ever had with dumps it sounds deeper and makes the cam lope harder.... especially with bullets or the like.
Old 02-11-2011, 05:14 PM
bayer-z28's Avatar
Nope.. Just amplifies or deadens what you've already got.
Old 02-11-2011, 05:46 PM
Captain Double Post
BOBS99SS's Avatar
Yeah I had a lm1 on my ms4 souded great at idle,then the magnaflow calmed it down so much,my fav set up to this day was a maggy cat back and dual cut outs
Old 02-11-2011, 06:45 PM
TXZ28LS1's Avatar
yes i think a change in catback can change the tone or sound of a cam as odd as that sounds. I have a 230 duration cam with longtubes, ory, and magnaflow and you couldnt hear it lope for ****. Now that i have TSP duals dumped, it sounds like a monster..
Old 02-11-2011, 09:09 PM
rob00ss's Avatar
thanks guys well true duals with sweet thunders are on the way im hoping it helps or its time for a ms3 or ms4
Old 02-11-2011, 09:12 PM
KevinR's Avatar
Yeah, it will help. Dump it if you really want to make some noise.
Old 02-11-2011, 09:31 PM
TXZ28LS1's Avatar
You will really love the sound of the sweet thunders. That is the setup i wanted, but i am now running TSP duals w/ dynomax bullets.
Old 02-11-2011, 09:37 PM
thegroup's Avatar
ur going to **** urself when u heard those sweet thunders fire up. at least i did when i put mine on and i had only intake tune and longtubes. completely stock block with 155,000 miles. i could only image what a cammed set will sound like
im getting ready to aintty up on the blue car (as seen below) and getting ready to pick up a 2000 SS and i will defently get another set of true duals w/ ST
