Alternator wire
Old 02-13-2011, 06:40 PM
97ss497's Avatar
Default Alternator wire
I removed the engine/trans a couple of weeks back from my 99 LS1; when removing the alternator I had a heck of a time getting the connector off and I broke the red wire off about .125 away from the connector. Should I get a complete pigtail or is soldering a piece of wire to the remaining wire ok? My manual has the wire size as .35 red. What gauge wire is this and if I go the soldering route can this be bought at any car parts store? If I go the pigtail route am I only going to be able to go to the dealer for it?
Does this wire go all the way to the PCM or is there a junction somewhere before the pcm?
Old 02-13-2011, 06:46 PM
ez money's Avatar
they sale these pigtails on ebay just search for them i bought one off there they cost bout 9.00 $$
Old 02-13-2011, 07:04 PM
97ss497's Avatar
Thanks for the quick response buddy, I just bought one for $11 off of Ebay :-).
Old 02-16-2011, 05:36 PM
97ss497's Avatar
Default Recieved pigtail
Got it quick; but noticed the wire size is much larger than the existing wire; which I believe is a single strand. Is this ok to use?
Old 02-17-2011, 06:10 AM
97ss497's Avatar
Come on electrical guru's! Will the stranded wire cause more resistance than the stock single strand wire? Is this a problem?
Old 02-17-2011, 07:02 AM
MTBSully's Avatar
did the exact same thing during my header swap:
-broke the same wire
-bought the same new wire off ebay
-soldered it up
Have been running it for 2k miles without any issues. Just go for it
Old 02-17-2011, 03:57 PM
a383z's Avatar
Multi stranded wire is suppose to be better and if the wire is a little bit bigger for any work i have done in the past i would say no you shouldnt have a problem... Go forth and prosper.. good luck
Old 02-17-2011, 06:30 PM
sjsingle1's Avatar
the current running thru the wire is not enough to cause a problem
