PCV Setups with sheetmetal valve covers....???
Old 02-13-2011, 11:25 PM
Silvy6.0's Avatar
Default PCV Setups with sheetmetal valve covers....???
What do you need for the PCV on these? Just drill and tap a hole? Been looking at them but didn't wanna pull the trigger just yet.
Old 02-14-2011, 10:21 PM
Silvy6.0's Avatar
Anyone???
Old 02-14-2011, 11:37 PM
Adam86's Avatar
Check this out...
https://ls1tech.com/forums/forced-in...-inside-3.html
Lots of good setups in here if you wish delete the PCV setup entirely. Otherwise, yes, you will have to drill and tap a couple of fittings to fit the PCV hoses onto the new covers. Not sure about the Nasty Performance ones, but for sure on the cheaper ebay ones you do.
I believe there is one fitting on each valve cover.
Old 02-19-2011, 02:59 PM
Silvy6.0's Avatar
Ok. Thanks man!
