ls6 install questions
getting ready to put the ls6 intake on my 98 trans am tommorow...waiting on a oil pressure switch to come in since I broke the stock one removing the ls1 intake.
This is the first time i have done this.
I did not by the coolant line, i just took the bottom of the intake and knocked of the tabs from some pics I seen this is mine.
I test fitted the intake this evening.
When I sit the intake down it did not wobble but it didnt sit all the way flat...very very very very small gap.
But I think this is the new seals in the intake..on the ls1 i pulled off the seals were flat into the intake smooth. the news stick out alittle...almost just as much as the small gap between intake and head.
I guess when I tighten down the intake it will for a good seal correct?
I kinda thing my old intake was leaking alittle...and all the pcv hoses were wrotten in half.
Edit also
the part on the new tb where the cable connects almost seems taller in a way...but it opens the same..I guess this wouldnt have an effect I'll have to try to be sure.
sorry if these seem like stupid questions im just paranoid and finally just working on my own stuff.
thanks
Edit also
thanks
Mine sat funny too. I used the stock steam vents. If I put a small bit of pressure on the intake, it would seat so I tightened it down. And I didn't break mine off, just dremeled them down.
And if the TB works, don't worry about it. Some have a different "cam" or quadrant. Whatever you want to call it.
Thanks, yeah I didn't press on it too hard and it went down alittle...I guess I will see when I bolt it down. Someone told me to re-use the stock seals, but with having new ones I would wrather use them, and the olds sit so flat to the intake I don't see how it woudl seal off. It even looks like the stocker may have leaked alittle.
Try not the break the opsu again putting it back on, I almost did. and dont forget the little vacuum line that goes toward the passenger side. I had a hell of a time finding the correct opsu from the parts store, they kept giving me the wrong one, the threads on the 98 opsu are larger than the later models. had to go to 3 different places to get the right one. had to drive for a week to work with the opsu hole plugged up.
I put a 1 inch extension on the opsu so now I can easily reach it without having to take the intake back off.
Yeah I had to order one, and I just ordered two to be sure, I think the hose that runs to the break booster broke mine. So i'm just gonna shove it under the fuel rail and run it when the intake goes back on.
I ordered two opsu's just in case.
For the brake booster hose, just run it on top of the harnesses and other junk back there. I made mine a little longer by adding some 1/2" hose with barb connectors. Then you don't have to route it thru anything when you put the intake back, and it won't hit the OPSU, and much easier to take it back out.
Just one more Q I don't have a torque wrench, but I know the intake bolts are night tigh at all..
I was just told to tighten them down to where they kinda get tight then go in sequence and give them one good turn and that's it.
I can get a ft'lb torque wrench but I know ther 44inch pounds...what would 44 inch pounds be on a ftlb torque wrench.
I also can get the crossover lines and block of plates today...just still paranoid about blocking the coolant line to the rear cylinders.
