pacesetters
Old 02-17-2011, 03:02 AM
earmuffs's Avatar
Default pacesetters
Dont worry, i read the sticky. I know what im buying, what i dont know is what y/x pipe i should or can run with these. thanks in advance for anyones help.
Old 02-17-2011, 04:26 AM
06Sierra2's Avatar
im running the texas speed one on my truck. what yr is your car?
edit: just seen 01 vette
Old 02-17-2011, 05:21 AM
earmuffs's Avatar
sp will the tsp x pipe work?
Old 02-17-2011, 10:13 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
I would recommend our Texas Speed headers over the Pacesetters. For a little more money you get longer tubes, a larger primary and collector, and the ability to run our 3" X-pipe!
http://www.texas-speed.com/shop/item...d=689&catid=45
Let us know if we can help!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 02-17-2011, 03:55 PM
earmuffs's Avatar
im trying to read the laws in missouri, if the cats are deleted would i fail inspection?
Old 02-17-2011, 05:38 PM
lsx24's Avatar
Until you can find the right set of crossover and cats, just hookup your headers right to your exhaust.
Old 02-17-2011, 05:42 PM
01transampower's Avatar
Idk about you but in colorado emissions is every 2 yrs so if its anything like that buy your headers hook them up and when it comes time to get emissions find some universal cats bolt them in and take them back out after. Just make sure the cas dont have to be in the stock location on the car.
Old 02-17-2011, 06:26 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
If they do a visual or sniffer test then you'll fail. If they only hook it up to the computer and check for any stored codes you'll be okay if you have the codes deleted
Old 02-17-2011, 06:41 PM
TXZ28LS1's Avatar
I am running pacesetters and was running the Y pipe that came with it. I had no problems with it at all. I am know running TSP Duals..
Old 02-17-2011, 09:15 PM
earmuffs's Avatar
so pacesetters with an off road x pipe will work as long as the codes are deleted?
Old 02-17-2011, 11:10 PM
94Z28-MSTGKLR's Avatar
Yes it will work just fine. After your instal just have it tuned. But that's only if you don't have a visual it sniffer test.
Old 02-20-2011, 09:18 PM
earmuffs's Avatar
I need a catted x pipe, that will bolt up to pacesetter LT. who makes one.
