Need help! (intake)
Old 02-22-2011, 04:30 PM
RAIDER's Avatar
Default Need help! (intake)
Well after almost being done chiseling the ribs on the bottom of my ls6 intake, I fucked up! I was chiseling it when it broke through the bottom of the intake..is there any any way to fix this? Please!
Old 02-22-2011, 04:43 PM
vette0009's Avatar
JB weld
http://jbweld.net/index.php
Old 02-22-2011, 04:51 PM
RAIDER's Avatar
Which product woul you recommend?
Old 02-22-2011, 04:52 PM
mike171562's Avatar
I would JB Weld the **** out of it. It should be ok.
Old 02-22-2011, 05:33 PM
Greekey's Avatar
Thats why I recommend grinding the ribs off with a dremel.
Old 02-22-2011, 05:38 PM
khaotic's Avatar
If you have a Matco tool dealer in your area they sale Q Bond its amazing for things like that. The stuff i pretty wild
Old 02-22-2011, 05:48 PM
JaYZeig's Avatar
x3 on the jbweld..too bad it wasnt closer to the t/b opening to where you can sand it down easier (if you were to do that)
Old 02-22-2011, 06:37 PM
bayer-z28's Avatar
That's what I did. These intakes can be brittle.
But yeah.. If you can find the piece, grab some liquid JB weld. Or the Matco epoxy.
Old 02-22-2011, 09:18 PM
RAIDER's Avatar
Thanks guys for all the replies..I was really stressing it and already dreading having to fork over another 300 for another one..
Old 02-22-2011, 09:26 PM
RAIDER's Avatar
Would of been so much easier knowing how much pressure I was actually putting on it..I was wincing before every blow..
Old 02-23-2011, 12:14 PM
redss86's Avatar
Ok call me an idiot, but what's the point/ benefit of removing the webbing? It's there for strength anyways isn't it?
Old 02-23-2011, 12:17 PM
Greekey's Avatar
Coolant lines run under the intake manifold. If you don't have coolant block off plugs for the rear and another front coolant pipe, you have to grind the ribs for it to fit.
Old 02-23-2011, 12:19 PM
redss86's Avatar
Ah I see, makes since
Old 02-24-2011, 08:32 PM
77BlueL82's Avatar
Default MarineTex
The stuff is great. A friend used it on his cracked block on a marine engine. Held up 6 years. Sold the boat, and the new owner never had any problems.
Old 02-25-2011, 01:09 PM
DeLaRosa25's Avatar
What bit for the dremel would you use to do it?
Old 02-27-2011, 06:48 AM
RAIDER's Avatar
Jb weld or the matco epoxy?
Old 02-27-2011, 07:34 AM
bayer-z28's Avatar
Regular Dremel (craftsman dremel is about the same) with the rotary cutting bit.
Old 02-27-2011, 09:43 AM
mike171562's Avatar
I just used a flat head screw driver and made sure to hit the ribs at a steep angle
