Emissions and Cats...
so i tried to search for what I was looking for maybe i wasn't searching the right key words...
So i'll be moving to Denver in a month or so. Right now I don't think I have a chance in hell passing emissions.
My car has a great tune on it but as you can see in my signature, I have long tubes no cats 3" ORY and TSP Rumbler... If I just add cats to my ORY make into an On-Road-Y, what are the odds of passing the sniffer... As of right now I won't even pass the visual inspection...
Is there a noise policy in Denver? if-so i'm screwed there too....
What Cats are going to give me least amount of power loss? Will i have to reprogram to put my back o2's back in?
any info/insight would be great - I really don't want to add cats..
!EGR......... crap, so would i have to put the egr back on? and trust me it wasn't the most refined removal mostly cut that that and this cap that and take that off... i'll have to buy all those parts... son - of - a - bitch
If your car isn't passing the tests even after all of that, then you could get a premium smog test and be done with it.
Dont worry about the visual as long as they see them your fine. I live in dever and have a similar set up. Find some regular cats that will support the engine size. Cut a section out of each side of your ory. Then weld a flange to each side of that cat as well as the pipes. Bolt the cats in for emissions then take them out and bolt the strait pipes in. its as easy as 1-2-3. Now they will bitch about no o2 sensors. Id put the front ones in. the back 2 dont worry about. If they say you need them, tell them **** off and to run it. you should be good.
