smooth bellow
Old 02-24-2011, 02:17 AM
00 black ss's Avatar
Default smooth bellow
so i need a bellow to fit in btw a fast 90 and a 85 mm maf. can someone tell me the size i would need and a link if possible.
Old 02-24-2011, 07:43 AM
RARON455's Avatar
Take a measurement of the throttle body inlet and the maf outlet, then you can look on couplers.com or ebay and find the size you need in an elbow. double check to make sure you get the right length, then when you get it cut it to fit. I have the 100mm maf and fast 92 setup, mine was a 4" coupler.
Old 02-24-2011, 07:55 AM
cookba's Avatar
3.5" but go down to your local home depot or lowes and get a Fernco. you can even walk in with the MAF and TB in hand.
Old 02-24-2011, 04:58 PM
garygnu's Avatar
airflo.com.
Old 02-26-2011, 12:52 AM
chrs1313's Avatar
http://intakehoses.com/Merchant2/mer...gory_Code=SAE0
needs to be trimmed but works great...
Old 02-26-2011, 01:10 AM
cowboysfan's Avatar
all great choices..
Old 02-26-2011, 01:50 AM
Zmg00camaross's Avatar
This works great. seen his post back in the day and bought it and trim it and with the slight bend it work perfect.
