Car spins but wont run unless you jump
Old 02-24-2011, 06:30 PM
jasons88gta's Avatar
Default Car spins but wont run unless you jump
My 2002 trans am will spin over but will not run unless you jump it i put a new battery and new cables. Even tried the battery out of a freind of mines car just to be sure. Im not sure if its a ground problem or maybe a short or something. the alternator is putting out 14.8v. The car it will cranks up on its own for a little while after the jump but if you wait about 15 mins it starts back just spinning. Im not sure what to check. Someone please help lol
Old 02-24-2011, 06:49 PM
LS6427's Avatar
What do you mean......"it starts back just spinning." After 15 minutes of the engine running.
Do you mean that after 15 minutes of it running...you tuen the engine OFF, then if you try to start it again (without a jump) it will only turn-over...but not start up?
Old 02-24-2011, 06:54 PM
afte you shut off the engine it will start right back up but if it sits for awhile it won't run
Old 02-24-2011, 06:56 PM
LS6427's Avatar
So....it will start and run for 15 minutes.....then if you shut it OFF after that 15 minutes, it will start up ON ITS OWN...but then after awhile it won't run? Meaning it will shut off on its own?
Old 02-24-2011, 07:00 PM
no it will keep running once you jump it. after i cut the car off then it sits awhile i will have to jump it again
Old 02-24-2011, 07:03 PM
LS6427's Avatar
Right, but if you let it run after it has been jump-started.....does it run 100% normally after that as long as its running?
So really.....you're only problem is: you need a jump start to get it started, right?
Otherwise, it runs normally after its started.......
Old 02-24-2011, 07:09 PM
the otherday when i jumped it i was going to move it out of the garage i did notice that it was acting like it has a big cam in it not wanting to idle. I do have a check engine light that shows tps
Old 02-24-2011, 07:12 PM
LS6427's Avatar
Well jeez....you need to replace that TPS sensor. I was going to also say you could have a seriously dirty MAF....Do you have a K&N filter?
Old 02-24-2011, 07:16 PM
will that tps sensor keep the car from running on it own
Old 02-24-2011, 07:20 PM
jim ravencraft's Avatar
Hi,
sorry to hear of your troubles!!!questions???????????
Fuel tank/do you have fuel? No insult to you.........fuel pump working??????
Fuel filter? Dirty/clogged
worn plugs?
Broken/loose wires ignition circuit?
Dirty injectors?
Bad ground/dirty terminals?
Timing chain? Not likely if car runs with jump?
Does battery have voltage after the 15 minute wait?
Hang in there you can do it!!!!!!!!!!! Use the process of elimination......
Fuel/fire-ignition/compression...........she will run.......have a blessed day!!!!
Captain jim
PS: LIKE 427/ QUOTED CHECK ALL AVENUES......NO MODS TO THROTTLE BODY/VACUUM LEAK...
Old 02-24-2011, 07:22 PM
LS6427's Avatar
Well, if its bad it will effect throttle position and fuel delivery.
You do have a code for it.
Look, go get a new one, slap it on and see if it fixes the problem. If it doesn't.....take the part back and tell them its the wrong one because someone modded your throttle body and you couldn't even try it. Tell them you COULD NOT put it on at all. They will give you a refund. They have to.
Old 02-24-2011, 07:26 PM
yes the fuel pump is working i put a fuel pressure tester i have put new battery cables new plugs and wires i do think its a ground problem
Old 02-24-2011, 07:27 PM
k thanks alot for all your help i will try the tps
Old 02-24-2011, 07:29 PM
LS6427's Avatar
I guess it could be a loose ground, but that usually causes allot of issues...and it won't throw a TPS code.
Old 02-25-2011, 12:22 AM
Cronic_Moronic's Avatar
TL / DR
Check your ground cable. My buddy's stratus did the same thing. It was a bad negative battery cable.
Old 02-25-2011, 09:35 AM
thunderstruck507's Avatar
Did you reuse battery terminals? If so, clean them with a terminal tool.
Did you clean the mating surface to the starter and wherever you have the ground hooked up?
Old 02-25-2011, 10:09 AM
Today I went and got a new neg battery cable and a new ground strap that connects to block to the frame I'm gonna put both of them on and clean all the connectors today when I get off work
Old 02-26-2011, 03:06 PM
99monguse's Avatar
Make sure you replace the starter relay too.
Old 02-26-2011, 03:11 PM
LilJayV10's Avatar
I am going to have to re read this thread because it's all over the place.
Do you need two batterys or a jump to get the car to turn over?
After you try and turn it over feel the battery cables and see if one is hot.
As thunder said check the grounds. If you are having electric problems it can show itself in other areas too.
If I am reading it right and you need a jump to get the thing to start there's a good chance the starter is pulling to many amps and needs to be replaced. Start with the basics and go from there.
If its turning over I wouldn't replace the starter relay.
Old 02-27-2011, 05:58 PM
I put a new ground cable off
The battery and it's seems to have fixed the problem
Quick Reply: Car spins but wont run unless you jump
